Introduzione
Prerequisito interno. Rimuovere la scheda madre per accedere alle connessioni dell'SSD.
Cosa ti serve
Nei passaggi seguenti dovrai scollegare i seguenti cavi:
Scheda SD
Speaker sinistro/destro e microfono
Porta audio
Antenna WiFi
Sensore della temperatura destro, sensore Bluetooth/luce ambientale/fotocamera/temperatura sinistro e ventola del disco rigido
Ventola CPU/temperatura ambientale e tasto di accensione
Sensore IR
Usa la parte piatta di uno spudger per fare leva e scollegare tutti i tre connettori delle antenne AirPort dalle loro prese sulla scheda AirPort.
For me it was originally the reverse order. No stripes for ch2, one for ch1 and two for ch0
As another user already posted, cables can be in the reverse order as depicted on the guide. Pay attention before disconnecting them.
E.g.:
To simplify this and since there seems to be some variable set ups, take a digital picture of the way it is before following this step so that you can put it back the way it was. (If no digicam then draw yourself a note with paper and pen).
Also for me reversed.
Also reversed for mi
I broke the pins, how can I repair it? Or where can I buy a new module? My pins are reversed as well
Usa le unghie su entrambi i lati del connettore del sensore della temperatura destro per spingerlo verso il bordo superiore dell'iMac e scollegarlo dalla sua presa.
Yeah, my wires came out without the socket connector. Then I tried pulling out the connector to fix and it was damaged. I’m going to try putting the wires back in independently. We’ll see how that goes…
Tira il connettore del tasto di accensione verso l'angolo inferiore sinistro dell'iMac per scollegarlo dalla sua presa sulla scheda madre.
Mine broke as well. At least it is only 50/50 chance. Plan to put together at the end - screen without screws - to check.
Mine came off bare ends as well. Managed to put them back. Seems like the connector on the cable is very fragile as my one came out in two pieces. The iMac is now up and running again!
Usa i pollici per spingere il connettore del sensore IR verso il bordo superiore dell'iMac e scollegarlo dalla sua presa sulla scheda madre.
Tira la scheda del sensore IR verso l'alto da dietro la parte anteriore della copertura esterna.
Rimuovi il sensore IR e mettilo da parte.
For some reason this connector was refusing to come out. I ended up just removing the IR sensor board, putting it in a tiny ziploc bag to protect the logic board and sensor and working around it. No worries at all.
Tira il connettore del cavo della presa audio verso il bordo sinistro dell'iMac per scollegarlo dalla scheda madre.
Rimuovi il cavo della porta audio dalla faccia della scheda madre e lascialo appeso come mostrato nella seconda immagine.
Svita le seguenti quattro viti dall'alimentatore:
Una vite Torx T10 con filettatura grossa da 9,3 mm
Una vite Torx T10 con filettatura grossa da 25 mm
Due viti con filettatura grossa da 22 mm
Tira gli angoli in alto a destra e in basso a sinistra dell'alimentatore lontano dalla copertura posteriore per smuoverlo dai supporti attaccati agli angoli dell'alimentatore.
I agree with kyoder11, no need to remove the power supply. But pay attention to not damage it when pull the logic board.
Solleva attentamente l'alimentatore dalla copertura esterna e ruotalo per accedere al blocco del cavo come mostrato, ricordandoti che i cavi di uscita DC e ingresso AC sono ancora collegati all'iMac.
Scollega il cavo di uscita DC sganciando il meccanismo di bloccaggio sul connettore mentre tiri il connettore stesso lontano dalla sua presa sull'alimentatore.
Dopo che il meccanismo di bloccaggio ha liberato la presa, tira il connettore dell'uscita DC via dall'alimentatore.
Tira leggermente la scheda madre lontano dal retro della copertura esterna, quindi sollevala per liberare la parte anteriore della copertura.
Be careful when balancing the mother board here, you can damage the RAM bays if not careful. (Had a friend do this, good by motherboard and iMac.) Just be careful and aware of how you have it sitting.
Before you lift the logic board, remove the infra-red receiver ( have a look at the logic board replacement guide )! It will make your life a lot easier.
Like stated also in the video, it's easier if you put the iMac on its foot again.
This was a great tip. Removing the IR made my life easier when putting the board back in place.
fansntt -
Per rimontare il dispositivo, segui le istruzioni in ordine inverso.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
