Introduzione
Use this guide to replace the sleep light/IR board.
Cosa ti serve
Strumento utilizzato in questo passaggio:Heavy-Duty Suction Cups (Pair)$16.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Pull the IR board connector toward the top of the iMac to disconnect it from the logic board.
