Salta al contenuto principale
iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement
Cosa ti serve
  1. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement, Glass Panel: passo 1, immagine 1 di 2 iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement, Glass Panel: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Compra
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
    Very easy to lift the glass out. Don't jerk too hard.
    kctipton - Replica
    Another comment on DATA & LCD Temp. Sensor cables: I had to remove the vertical sync, and the backlight cable, however, if you have an assistant or/can carefully rotate the screen clockwise/and then have it held up about 5" to 6" at a slight angle, you do not need to remove LCD data cable or LCD thermal cable, however - IMPORTANT: you must have a second pair of hands/or way to securely prop up the LCD. Also, don't rotate too much, since then you will pull out LCD data cable, and it renders the whole exercise moot, or can damage the cable or connector.
    MaximBorzov - Replica
    You don't need suction cups. The screen, held by magnets, can simply be pried off using a very thin blade such as a screw driver and fingers.
    Deepsurvival - Replica
    That's a bad idea. using a metal tool to pry off glass is likely to end with an expensive broken front glass.
    Suction cups are common. Find a couple and do it the safe way. I use some cheap ones that came with iPhone repair kit.
    max damage -
    No need for suction cups, I just stuck my nails (short like guys usually have) between the top part of the screen and body, and it came off easily. I've never done it before, so it seems to be very easy.
    Nikolas Lintulaakso - Replica
    Nails worked for me too
    Rob Dale - Replica
    Just completed the replacement of the optical drive with an SSD using an OWC Data Doubler kit. Attempted to remove the optical drive without disconnecting any cables but found it a bit fiddly to orient the screen for good access. I bit the bullet and disconnected them and found the process less daunting than I imagined. Reconnecting them was similarly straightforward if you're careful.
    Tip: you can skip the step for removing the optical drive thermal sensor connector from the motherboard. Still need to remove the sensor from the optical drive but you can leave that hanging and reattach it to the SSD later.
    osienna - Replica
    I use Garmin GPS suction cup. Work very well
    jc3Dcx - Replica
    I’ve just successfully installed a 1TB SSD in place of my optical drive thanks to the information here- thank you to everyone who has contributed!
    3 comments- the procedure described here seems to vary between HD replacement and dual HD/optical drive replacement. This can be confusing at times.
    Expect there to be minor differences between the layout described and what you find when you open up your iMac. There are also, surprisingly, differences between the HD enclosure description, and the article provided by ifixit.
    I was able to replace the DVD/HD enclosure single-handedly without fully removing the LCD, or deconnecting any of the cables (steps 5-11). It’s a bit cramped, and fiddly, but I was not happy removing any of the cables despite watching videos, etc., since they all seemed to involve applying more force than I was comfortable with. A more detailed description of how to release them might have helped, but even here, there may be minor variations even within the 2389 model.
    Good luck!
    ivan birks - Replica
    I did it several times with one suction cup at the end of a kitchen brush. Once with the blade of a swiss army knive, also ok. And i’m pretty sure it works with fingernails too
    Tai - Replica
    Fingernails are all you need to free the glass from its magnetic hold. If you don’t have them, slip something thin and plastic, like a spudger, at a top corner.
    Max Powers - Replica
    Minha dúvida é a seguinte: após o técnico trocar o HD do meu iMac de 21,5 polegadas, a câmera parou de funcionar. Seria por causa da troca do HD? Tem solução?
    Claudio - Replica
    Creio que o cabo da camera não foi plugado ou deu mau contato… ou até danificado.
    glecyo@gmail.com
    glecyo medeiros -
    I can’t get my glass to budge. I’m replacing a cracked one and now it’s about to shatter.
    jamboxmitchell - Replica
    I know that I'm replying really late but I advise to use clear tape over any cracks so the cracks don't get bigger
    Jace Holmes -
    Check for chips in the glass BEFORE you do this step. If there is a chip when you pull up with the suction cups you will wind up with a jagged mess. If you do have a chip I would advise covering the screen near the chip with clear tape of some kind before lifting out. Mine shattered right at the chip and the resulting glass dust cloud got all over. My solution was buying a new glass screen.
    BCam - Replica
  2. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 2, immagine 1 di 2 iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 2, immagine 2 di 2
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
    What's the best product to clean the face of the LCD?
    Steve Speirs - Replica
    Microfiber Cloth
    Leonardo Fournier -
    Try your best not touch it in the first place
    Brian -
    Wearing Nitrile or regular surgical gloves helps prevent finger prints if you accidentally touch the glass.
    amiller770 - Replica
    I use a Swiffer duster from above at the last moment before I let the magnets grab the glass cover. This has worked so well the last dozen or so times I’ve replaced a glass cover since I never have access to a “clean room” and don’t wear a “bunny suit”.
    Also, more dust will shed from your skin if you’ve just taken a shower, so I like to finish these repairs in the morning before a shower.
    gatortpk - Replica
  3. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement, Display: passo 3, immagine 1 di 3 iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement, Display: passo 3, immagine 2 di 3 iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement, Display: passo 3, immagine 3 di 3
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
    The metal near the screws is VERY magnetic. Honestly, the hardest and by far most frustrating step was trying to put these screws back in.
    seancourtney - Replica
    I ran into the same problem - easily the most frustrating part of this process. To help deal with it, I took a drinking straw, cut it to be about 2 inches long, and used it as a chute to guide the screw to the hole. Dropping the screw down the straw, it'd still stick to the side due to the magnets, but using my screwdriver, it was easy to push the screw down to where it needed to go, and the straw kept the screw from being pulled out of place by the magnets.
    josh -
    +1 for the straw tip. Worked a treat!
    osienna - Replica
    Hmm… yes, the magnets sucks - literally. But if you use a normal screwdriver or a bit, the screwdriver tip or the bit can be “loaded” by the magnets too. Just move the screwdriver (or bit) over one of the magnets and then “plug” the screw onto the screwdriver’s tip (or bit). It will be held by magnetic force. Just enough to move the screw vertically and very slowly into the whole.
    There are some special screwdriver on the market with “claws” to hold screws, but they are hard to find/to buy and expensive. I sometimes use superglue (a LITTLE) to temporary fasten the screw at the screwdrivers tip. This technique can be used with destroyed screw heads too to optimize adhesion.
    Udo - Replica
    Les vis sont inévitablement aimantées
    Gui - Replica
    Replacing these screws was like playing the most difficult game of “Operation” imaginable. I wish I’d seen the tip about using a straw before I started playing!
    Bret Mogilefsky - Replica
  4. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 4, immagine 1 di 1
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board. Twisting or pulling the display assembly with the cables attached will damage your iMac.
    You can use one hand to hold the edge up while reaching with the other hand to disconnect cables. You may want to have a prop handy (like a small book) or an extra person to hold the edge up while you disconnect cables.
    kctipton - Replica
    Use the teardown guide for your iMac to familiarise yourself with the layout of everything before you dive in. I was able to get an idea of how much clearance there was once the display is unfixed from the frame, where the optical drive was relative to the base etc
    osienna - Replica
    The harddisk can be removed WITHOUT the next steps. The opening angle of the partially lifted LCD display gives enough room to untighten the two Torx T9 screws of the hard disk bracket, to unplug the two SATA connectors and to carefully lift out the harddisk. There is absolutely no need to dismantle the whole thing.
    All you need is a screwdriver which fits into the room. I’ve used the “Pro Tech Toolkit” from iFixit. The screwdriver with Torx T9 bit fits perfectly.
    The other “tool” you need is either someone who holds the LCD plate or the inner leftover of a kitchenroll, a scrunched paper, a small towel or similar which has to be stuffed between the logic boards and the LCD plate to keep the LCD at its lifted place (careful! don’t unplug any of the cables).
    I’ve opened and changed the harddisks of those 21,5 iMacs a dozen times with the help of the “Pro Tech Toolkit” and a kitchen roll.
    Udo - Replica
    If i want to replace the HD with a SSD, can i still skip the next steps? I think i can’t because i need to change the termal censor, but i would like an other opinion please.
    Danois -
    “Kitchen Roll” - paper towel core.
    kyoder11 -
    You can absolutely replace the drive without removing any cables. It's a little tight, you need your torx driver to be short enough to fit in the limited space. Be careful not to put any pressure on the cables (the one nearest the front is a good guide of how much space you have to play with). It's helpful to have another set of hands to hold it up while you remove the drive, but I just did it by holding the display up with one hand and it wasn't that hard to remove and replace the drive.
    I wouldn't install any thermal sensor, just use something like Macs Fan Control (free) to adjust the fans so they don't race out of control.
    maccentric -
    Hia,
    thx to IFIXIT and 20+ years of computer repair and building experience (all PC) there was no problem at all to remove a 500 Gb HDD from a mid 2011 iMac and replace it with an 500 Gb SSD Drive (with help from Comtec EDV, where i bought the upgrade kit).
    Skip the steps where people are advised to remove the display. Due to my experience it is def better to leave cables and plugs where they are. I lifted the display 12 cm and fixed this position w/ one pencil in each front corner of the case where the other end of the pencil sticked in ascrew hole of the display-frame. Very easy to operate afterwards! No probs w/ the screws of the hdd-frame.
    Some care-taking of static electricity is advised - wear a wrist cable. And don’t forget to press start button after having removed power chord. I had an Android Tablet on the right side, where i could watch these ifixit pages :-)
    thx to IFIXIT!
    w/ regards from cantbtroo from Berlin
    Hans- Peter - Replica
    Thank you ifixit for the guide. Like so many others I jumped from step 4 to step 10 and left all the cables intact. Felt much safer doing so. Papertowel cores secured the LCD to higher position. There was enough room to remove the old HDD and replace it with a SSD drive.
    Cheers!
    Aapo Kaivosoja - Replica
    I also was able to proceed with rest of instructions, after skillping steps 4-10, just have to be very gentle, i think it would help to have a second set of hands to hold screen above while other hands are uninstalling and installing hard drive, but i was able to do it on my own
    jacob d - Replica
    If you have trouble lifting the LCD or accessing the connectors, check if you have removed the right screws. There are a lot of identical Torx screws that are accessible without removing the LCD that have nothing to do with the screen, I learnt that by nearly breaking mine xD
    Luther - Replica
  5. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 5, immagine 1 di 2 iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 5, immagine 2 di 2
    • Pull the vertical sync cable connector out of its socket on the LED driver board near the top left corner of your iMac.
    Tried doing this on my iMac, but this cable would not come out for love or money. No matter what I did, I could not unplug this cable. My iMac is the same 21inch 2011 as this one. Any advice would be greatly appreciated.
    louis.barr - Replica
    use a little poker type thing in your right hand to push on the 2 holes that are on top of the plug and wiggle it out with your other hand,
    Nicholas - Replica
    I was tempted to forgo steps 4-10 but found the inside of the case to be very dusty and decided to do the full disassemble. I struggled getting this vertical sync cable connector out. The trick that worked for me was to prop the display up using a pair of toilet paper tubes then using the fingernails of both thumbs, one on each side of the connector and it came out easily.
    Anthony Zimmerman - Replica
    Great idea of using toilet paper tubes to prop up the LCD! Thanks.
    jim - Replica
  6. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 6, immagine 1 di 2 iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 6, immagine 2 di 2
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
    Slip a thumbnail under the “front” (toward the top of the iMac) of the connector to release its clamp from the retaining ridge. Then push toward the “back” (bottom of iMac).
  7. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 7, immagine 1 di 3 iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 7, immagine 2 di 3 iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 7, immagine 3 di 3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it towards upwards.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    I am having a difficult time reattaching the LCD cable. A better description or any tips would be useful here.
    Ben Bauermeister - Replica
    Me too — ditto that.
    Roger Buttermore -
    https://eshop.macsales.com/item/OWC/DIDI... —> abt. 5:30 into the vid. Handle up to slide in, then flip it down to lock the connector in place.
    Roger Buttermore -
    The connector needs to be carefully pushed in parallel to the board with a surprising amount of pressure and the pull tab must be folded back. Not super fragile, but not strong either.
    Isaac Vande Zande - Replica
    I really wish that the fagility of this connector was mentioned in Step 10 or 11.. When i rotated the screen on step 11.. It pulled this connector out and now I can't get it back in.. I hate computers.. HA!
    Philip Nelson - Replica
    This is the most painful part of the whole event. Replacing this cable took me around 30 minutes !
    K. Efe Egilmez - Replica
    I have tried and tried to get this cable back in. How do I know if I have messed it up?
    Christopher Teer - Replica
    Mine seems to be…upside down? Looks like the little flappy lock thing is on the bottom as opposed to it being in top as pictured?
    jinnifer douglass - Replica
    I agree with everybody that this is the critical step in this fix. Removing it is not that difficult, the description is quite accurate, but I would highlight that the “rotate” part of the step could be detailed: the black plastic tab is attached to the metal lock (golden colored) , which should rotate into the direction of the cable almost 180 degrees to unlock the connector. After doing this you can pull the cable out of the connector, PARALLEL to the board and away from the connector. It travels a very short distance to disconnect. After going through the rest of the steps to remove the display, take some time to examine closely the connector and understand what you have to do to reconnect it on assembly. It helps to fully visualize beforehand, since on reassembly it is difficult to see properly.
    Fernando Walker - Replica
    Magnifying glasses are needed for this step. Carefully study the cable and how it attaches to the connector. Take a few pictures to help. This is the most difficult step.
    Norman Staples - Replica
  8. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 8, immagine 1 di 2 iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 8, immagine 2 di 2
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    When putting the display down on the table, be careful not to kink the flat ribbon cable.
    frank - Replica
    The replacement hard drive I used doesn't even appear to spin up and the Time Capsule restore process doesn't show it as available. It just stays at Searching for disks and never finds it.
    JRBv3 - Replica
    I had to use Disk Utility to partition the drive and then it showed fine. Rookie mistake.
    JRBv3 -
    I managed to damage the LCD thermal sensor socket in the logic board. Now the connector won’t stay in place. I know the missing thermal sensor should cause the fans to spin up (they do spin up after a while), but the screen is blank.
    I connected an external monitor and it works fine, so it doesn’t seem to be a graphics or logic board issue. I also replaced the LED driver board with one from a working iMac, to no effect.
    Can the missing thermal sensor be causing this?
    Rodrigo da Rosa Cesconeto - Replica
    Having the same problem. Black screen, works fine with external display.
    Passerby -
  9. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 9, immagine 1 di 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
    Btw, I was pretty safe (& content) with two suction cups - i bought 3 for less than 7 Euros. They were a good help for a glass that hasn’t been removed since 2011. But i am sure fingernails will do a good job, too (of course not mine, cos i have short ones).
    At the end of the job it was even possoible to clean the fan that sucks cool air into the iMac (w/ a paintbrush and a controllable vaccuum cleaner). After that, it’s also a good opportunity to clean the air inlet that is part of the aluminium case (behind the stand - it’s always dusty).
    w/ regards from cantbtroo, Berlin
  10. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement, Bluetooth Board: passo 10, immagine 1 di 1
    • Use the flat end of a spudger to pry the Bluetooth antenna cable connector up from its socket on the Bluetooth board.
  11. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 11, immagine 1 di 1
    • Remove the single 6.6 mm T8 Torx screw securing the Bluetooth board to the outer case.
  12. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 12, immagine 1 di 1
    • Remove the piece of tape wrapped around the Bluetooth board.
  13. iMac Intel 21.5" EMC 2428 Bluetooth Board Replacement: passo 13, immagine 1 di 1
    • Disconnect the Bluetooth cable by pulling its connector away from the socket on the Bluetooth board.
    • Remove the Bluetooth board from your iMac.
Conclusione
Altre 5 persone hanno completato questa guida.
2 Commenti
Seriously this is so incomplete! What about the cable that connects the Bluetooth to the logic board!?!??? Like this is so half way explanatory!
mamashannon4u - Replica
it is much easier to replace the bluetooth board if you first remove the glass panel, then remove the 8 screws from the display and carefully lift it about 7-8cm without detaching the cables. With the top of the iMac facing towards you, fix the position of the display with something like a thick book and you should be able to remove and replace the bluetooth board easily.
michael walsdorff - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 35
Tutti i Tempi: 19,348
