Introduzione
Replace the LED driver board to fix a non-functioning display backlight.
Strumenti
Parti
Nessuna parte specificata.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Remove the two 9 mm T10 Torx screws securing the LED driver board to the outer case.
Altre 4 persone hanno completato questa guida.
