Introduzione
Rimozione del pannello di vetro per accedere ai componenti interni dell'iMac.
Cosa ti serve
Estrai delicatamente il pannello di vetro dall'iMac.
Another approach that worked for us was to get 4 small plastic wedges (the kind used in iphone screen replacements). Working one corner at a time you can use a cheap suction cup to pry just that corner up enough to slide the wedge in. Then proceed to the next then next, etc. Once all 4 have the wedges under them the glass should be away from the body all the way around, then just carefully lift it the rest of the way up.
Per riassemblare il dispositivo, segui queste istruzioni in ordine inverso.
Altre 13 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
A good alternative to the two heavy duty suction cups is a regular household plunger.
Russell Knight - Replica
Also, 2" wide packing tape. Maybe a 6 or 8" piece, folded in the middle to give you say, a 1-2" "handle". Make a pair of these. They look like a capital T but with a short vertical part (the handle), and a wide top I the sticky wings). Get the good 3M tape, it's strong, and it peels off clean without leaving any glue from the screen.
Barry Coyle - Replica
for me one household plunger did the trick!
Ronald Huygen - Replica
