Salta al contenuto principale
iMac G5 20" Model A1145 PRAM Battery Replacement
Cosa ti serve
  1. iMac G5 20" Model A1145 PRAM Battery Replacement, Access Door: passo 1, immagine 1 di 1
    • Orient the iMac face-side down on a table with the bottom edge facing yourself.
    • Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
    • The screws are captive in the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
    As you remove the screws during these steps, place them on a towel or a piece of cardboard. With a Sharpie label a piece of masking tape with the step number from which they were taken from. Then place the removed screws under the tape.
    This ongoing step will aid in you having control on your reassembly without searching for and identifying the size and length all the screws that you are about to remove.
    R51801 - Replica
  2. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 2, immagine 1 di 1
    • Remove the access door.
  3. iMac G5 20" Model A1145 PRAM Battery Replacement, Front Bezel: passo 3, immagine 1 di 1
    • Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
  4. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 4, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 4, immagine 2 di 2
    • Turn the computer over.
    • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
  5. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 5, immagine 1 di 1
    • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
    you might have more luck by gently leveraging the stand up
    Joseph A Borg - Replica
  6. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 6, immagine 1 di 3 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 6, immagine 2 di 3 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
    • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
    • Alternatively, you can use a strong magnet by holding it to the front top left/right corner of the display. You will hear a snapping sound when the hatch is released.
    If it still does not release try pressing in and out (like an accordion) with the card in one hand and the screen bezel in the other until it pops loose.
    rick - Replica
    If your computer has ever been worked on by an authorized Mac repair shop, this step may not be needed. I was able to skip this step after lifting the lower edge of the front bezel. Front bezel lifted off easily.
    Timothy Walsh - Replica
  7. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 7, immagine 1 di 1
    • Lay your iMac stand-side down on a table.
    • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
    • Lay the front bezel above the rest of the iMac.
    My A1145 seems to be attached, somehow, on the top via some silver looking strips. It does not seems to want to come off. Is that the wireless?
    Chris Arnold - Replica
    NO they are clamps on each of the top inside corners of the outside bezel (frame ) if you use a Heavy Spudger Tool & pry not too hard just slightly between the bezel (side) and the display (side) this should pop each off usually by just popping one or the other sides the second will automatically pop as well.
    Mark Meininger -
  8. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 8, immagine 1 di 1
    • If necessary, remove the piece of kapton tape wrapped around the microphone and camera connectors.
  9. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 9, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 9, immagine 2 di 2
    • Disconnect both the camera and microphone cables.
  10. iMac G5 20" Model A1145 PRAM Battery Replacement, Display: passo 10, immagine 1 di 1
    • Remove the two T6 Torx screws securing the display data cable connector to the logic board.
  11. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 11, immagine 1 di 1
    • To disconnect the display data cable, grab its connector's black tab and pull it away from the face of the logic board.
  12. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 12, immagine 1 di 1
    • Peel back the two EMI tape strips from the left and right edges of the display.
    • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
  13. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 13, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 13, immagine 2 di 2
    • Remove the four recessed T10 Torx screws securing the display to the rear case.
    • Bit drivers tend to be too short to reach these screws. Be sure to have a magnetic thin-shafted T10 Torx screwdriver on hand.
    When I removed the 4 screws, my bit wasn't magnetic enough to pick them out and they fell in. I could only retrieve 2 of them. Have a strong magnetic bit! Lucky for me, I was only using this guide to remove the hard drive so I could recycle my old computer.
    Ruth - Replica
    The 64 Bit Driver kit does not include a thin-enough, thin-shafted T10 Torx screwdriver. Where to get one of these?
  14. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 14, immagine 1 di 1
    • Lift the lower edge of the display slightly out of the rear case.
    • Disconnect both inverter cables (shown in red) by pulling their connectors toward the bottom edge of your iMac.
  15. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 15, immagine 1 di 1
    • Lift the display until it is nearly perpendicular to the rear case.
    • Disconnect the remaining two inverter cables (shown in red) by pulling their connectors toward the top edge of your iMac.
    Steps 17 and 18 are not strictly necessary if one simply props up the LCD display into a vertical position while the hard drive is removed and replaced. It worked for me anyway!
    I would like to send out a big thank you to Andrew Bookholt for submitting this extremely helpful guide!
    Mark Orwoll
    Mark Orwoll - Replica
    Prop the screen with something soft (plastic or wood) so as not to scratch the screen coating.
    Mark - Replica
  16. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 16, immagine 1 di 1
    • While holding the display perpendicular to the rear case, pull it upward to peel off the EMI shield stuck to its upper edge.
    If you are changing the power supply - this is a good point to remove the screws to the old power supply to see if the connectors (both of them) are accessible. If you can gently (but firmly) pull the power connector out from under the chassis, you can install the new unit at this step - saving hours of work.
    philaro - Replica
    See note to step 44 to easyly remove the power supply without dismantling the whole computer (as also suggested by philaro).
    danman - Replica
  17. iMac G5 20" Model A1145 PRAM Battery Replacement, Logic board: passo 17, immagine 1 di 1
    • Disconnect the IR board cable by pulling its connector away from the socket on the IR board.
  18. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 18, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 18, immagine 2 di 2
    • Remove the two T6 Torx screws securing the IR board bracket to the IR board.
  19. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 19, immagine 1 di 1
    • De-route the IR cable from under the aluminum heat sink and tuck it behind the optical drive to keep it out of the way.
  20. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 20, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 20, immagine 2 di 2
    • Remove the single T10 Torx screw securing the left speaker to the rear case.
    • The screw for the left speaker has coarse threads.
    • Lift the left speaker out of the rear case and de-route its cable across the logic board.
  21. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 21, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 21, immagine 2 di 2
    • Remove the single T10 Torx screw securing the right speaker to the rear case.
    • The right speaker screw has fine threads.
    • Lift the right speaker out of the rear case, minding the short cable between the speaker and its connector (located slightly above the right speaker).
  22. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 22, immagine 1 di 1
    • Disconnect the speakers from the logic board by pulling their connector toward the top edge of the iMac.
  23. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 23, immagine 1 di 1
    • Remove the two Phillips or two T6 Torx screws securing the AirPort/Bluetooth board to the logic board.
  24. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 24, immagine 1 di 1
    • Use your finger to lift the AirPort/Bluetooth board from its left edge, disconnecting it from the logic board.
    • Lift the board from its left edge only.
  25. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 25, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 25, immagine 2 di 2
    • Use the flat end of a spudger to pry both antenna cable connectors up off the AirPort/Bluetooth board.
  26. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 26, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 26, immagine 2 di 2
    • Disconnect the DC-in cable by simultaneously depressing both locking arms and pulling its connector away from the socket on the logic board toward the top of your iMac.
    • After both locking arms pass their retaining tabs, it is helpful to push the arms toward the top edge of your iMac while wiggling the connector.
  27. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 27, immagine 1 di 1
    • Disconnect the ambient light sensor by pulling its connector away from the face of the logic board.
  28. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 28, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 28, immagine 2 di 2
    • Disconnect the optical drive fan from the logic board.
    • To aid in removal, it is helpful to use both of your thumbnails to push the ears on either side of the connector toward the top edge of the iMac.
  29. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 29, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 29, immagine 2 di 2
    • Disconnect the IR/camera cable from the logic board.
    • This connector is especially wide and prone to breakage.
    • To aid in removal, it is helpful to use one hand to pinch the cables against a spudger and pull up toward the top edge of the iMac while pulling up gently on the cables with your other hand.
  30. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 30, immagine 1 di 1
    • Disconnect the optical drive thermal sensor cable from the logic board by pulling its connector toward the left edge of the iMac.
  31. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 31, immagine 1 di 1
    • Remove the two T6 Torx screws securing the optical drive connector to the logic board.
  32. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 32, immagine 1 di 1
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
    • It is helpful to insert the spudger under the top or bottom edge of the connector and twist to separate the connector from the logic board.
  33. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 33, immagine 1 di 1
    • Disconnect the CPU fan from the logic board by pulling its connector toward the top edge of the iMac.
  34. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 34, immagine 1 di 1
    • Disconnect the hard drive thermal sensor from the logic board by pulling its connector toward the top edge of the iMac.
  35. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 35, immagine 1 di 1
    • Disconnect the hard drive fan by pulling its connector away from the face of the logic board.
  36. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 36, immagine 1 di 1
    • Disconnect the power button cable by pulling its connector away from the face of the logic board.
  37. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 37, immagine 1 di 1
    • Remove the two T6 Torx screws near the top of the heat sinks.
  38. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 38, immagine 1 di 1
    • Remove the following seven screws securing the logic board to the rear case:
    • Three coarse-thread T10 Torx.
    • Three fine-thread T10 Torx.
    • One long coarse-thread T10 Torx.
    Two T10s are reversed. The bottom T10 to the right of the RAM should be fine-thread. The one directly above it should be coarse-thread.
    mike - Replica
    Confirmed - is the same in my computer.
    Ulf Springer - Replica
  39. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 39, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 39, immagine 2 di 2
    • Tuck the RAM arms into the iMac so they rest on the perforated metal grille along its lower edge.
  40. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 40, immagine 1 di 1
    • Rotate the top of the logic board toward yourself slightly.
    • Pull the right edge of the logic board toward yourself slightly to free the I/O ports from the rear case, being careful not to bend the board.
    • Continue rotating the board toward yourself until you have enough room to reach the SATA connector, shown in the next step.
  41. iMac G5 20" Model A1145 PRAM Battery Replacement: passo 41, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement: passo 41, immagine 2 di 2
    • Continue rotating the board toward yourself until you have enough room to reach the SATA connector (shown in red).
    • Insert the blunt end of a metal spudger between the SATA connector and its socket. Twist the shaft of the metal spudger to separate the connector from its socket.
    • Disconnect the SATA cable from the logic board.
    • Lift the logic board out of the rear case by its edges, minding any cables that may get caught.
  42. iMac G5 20" Model A1145 PRAM Battery Replacement, PRAM Battery: passo 42, immagine 1 di 2 iMac G5 20" Model A1145 PRAM Battery Replacement, PRAM Battery: passo 42, immagine 2 di 2
    • Use the flat end of a spudger to pry the PRAM battery (type CR2032) out of its housing on the logic board.
    • Use your fingers to remove the PRAM battery from its housing.
    • Don't bend the metal retaining clip up too far as it is brittle and easily broken.
Conclusione
Altre 8 persone hanno completato questa guida.
2 Commenti
The PRAM battery is a standard CR2032.
Simon Howes - Replica
Could this battery's failure be the reason my iMac died and is now completely unresponsive?
skat1140 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 51
Tutti i Tempi: 26,165
