Salta al contenuto principale
iMac G5 20" Model A1076 Fan Duct Replacement
Cosa ti serve
  1. iMac G5 20" Model A1076 Fan Duct Replacement, Rear Panel: passo 1, immagine 1 di 1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 20" Model A1076 Fan Duct Replacement: passo 2, immagine 1 di 2 iMac G5 20" Model A1076 Fan Duct Replacement: passo 2, immagine 2 di 2
    • Lift the rear panel slightly near the bottom of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 20" Model A1076 Fan Duct Replacement, Fan Duct: passo 3, immagine 1 di 1
    • Remove the following two screws:
    • One 11 mm T10 Torx.
    • One 10.6 mm T8 Torx.
  4. iMac G5 20" Model A1076 Fan Duct Replacement: passo 4, immagine 1 di 1
    • Lift the fan duct out of the chassis.
Conclusione
Altre 5 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 9,138
