Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Regain Bluetooth functionality by replacing the Bluetooth board.
  1. Lay the iMac display-side down on a flat surface.
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. Lift the rear panel slightly near the bottom of the iMac. Pull the rear panel toward yourself and remove it from the iMac.
    • Lift the rear panel slightly near the bottom of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. Kit cacciaviti Manta
    112 punte per ogni riparazione.
    Upgrade Your Toolbox
  4. Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
    • Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
  5. Bend a paper clip into a hook and use it to pull the Bluetooth board up off its socket on the logic board. Bend a paper clip into a hook and use it to pull the Bluetooth board up off its socket on the logic board.
    • Bend a paper clip into a hook and use it to pull the Bluetooth board up off its socket on the logic board.
  6. Use a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
    • Use a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 9,579
