Introduzione
Is your iMac always mute? Replace your blown out speakers to keep your iMac singing like it should.
Cosa ti serve
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
Remove the single 5 mm T6 Torx screw securing the IR board bracket to the logic board.
Remove the IR cable finger and move the IR board, with cable still attached, out of the way.
Altre 2 persone hanno completato questa guida.
