Introduzione
Replace your broken optical drive to keep those disks spinning.
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
Remove the T10 Torx screw securing the optical drive flex cable mounting bracket to the logic board.
Remove the flex cable mounting bracket.
Use the flat end of a spudger to press the bottom edge of the lower optical drive bracket release tab toward the lower edge of the iMac.
Maneuver the optical drive out of the rear case, minding the two plastic pins molded into the rear case near the open end of the optical drive that can break off.
Altre 7 persone hanno completato questa guida.
