Salta al contenuto principale
iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement
Cosa ti serve
  1. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate: passo 1, immagine 1 di 1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: passo 2, immagine 1 di 1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: passo 3, immagine 1 di 1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate Housing: passo 4, immagine 1 di 2 iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate Housing: passo 4, immagine 2 di 2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: passo 5, immagine 1 di 2 iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: passo 5, immagine 2 di 2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  6. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Logic Board Assembly: passo 6, immagine 1 di 1
    • Gently remove the cables marked in red.
  7. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: passo 7, immagine 1 di 1
    • Remove the three metal 10mm T-15 screws.
    • Remove the one nylon 10mm T-15 screw.
  8. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: passo 8, immagine 1 di 1
    • Using thumbs and forefingers, firmly grasp the battery holder in one hand while grasping the metal bar in the other. Gently lift and pull the logic board to release it.
Conclusione
Altre 9 persone hanno completato questa guida.
Justin
Membro da: 10/05/11
303 Reputazione
3 Guide realizzate
Cal Poly, Team 21-22, Maness Fall 2011 Membro di Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 Membri
13 Guide realizzate
Un commento
We need to say what cables to remove in step 6 of Logic Board Assembly
Courtney - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 36
Tutti i Tempi: 10,628
