Salta al contenuto principale
Introduzione
Upgrade your RAM DIMM Module for more memory.
Ricambi
Nessuna parte specificata.
  1. Place the computer monitor face down on a safe, harmless surface. Using a  Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. Remove the metal plate from bottom of the iMac G4.
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM. These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
Conclusione
Altre 10 persone hanno completato questa guida.
Ryan Kozak
Membro da: 10/10/2011
1.609 Reputazione
3 Guide realizzate
Cal Poly, Team 5-32, Amido Fall 2011 Membro di Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Membri
8 Guide realizzate
Un commento
Please correct the title, this is a 144 pin SODIMM, it is not a DIMM
The 168 pin DIMM is used in the internal socket.
Canadaram - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 5,305
