Introduzione
This is the teardown for the Apple iMac G3 Model M4984. I don’t think there is much more to say before beginning.
Cosa ti serve
The iMac G3. This was a great computer for the time, and had plenty of features.
To remove the bottom cover, remove these phillips screws, and pull the bottom cover off the iMac. (Start with the very back and use a flat head screwdriver to pop the main clip. The rest will come off relatively easily.)
2Commenti sulla guida
yo what happened to this lmao
The last step was left off by the previous post. The last plastic piece to pull is tricky. Do not try and pry it off because there are literal hooks that link with the inner shroud. You CAN get it off with a little muscle once you understand how they hook inside. Here is a video from MOOT that explains. Basically, the trick is (with the iMac on it's bottom, CRT facing you), you must yank the sides upwards to unhook them. then you can work them out.
