Introduzione
Use this guide to open the device because the steps will become difficult when removing the top of the device. You will need to make sure the power on the device is off and unplugged to prevent injury. You will need and iOpener or heat gun to heat to put of the edges of the device as it will be difficult to remove without the iOpener and may cause damage to the device.
Cosa ti serve
Make sure you remove all seven 3 mm screws before proceeding to the next step.
