Salta al contenuto principale
iLive IKBC384S Power cord and connector Replacement
Cosa ti serve
  1. iLive IKBC384S Power cord and connector Replacement, Top Cover: passo 1, immagine 1 di 2 iLive IKBC384S Power cord and connector Replacement, Top Cover: passo 1, immagine 2 di 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Power cord and connector Replacement: passo 2, immagine 1 di 2 iLive IKBC384S Power cord and connector Replacement: passo 2, immagine 2 di 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Power cord and connector Replacement: passo 3, immagine 1 di 2 iLive IKBC384S Power cord and connector Replacement: passo 3, immagine 2 di 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Power cord and connector Replacement, Power cord and AC connector: passo 4, immagine 1 di 1
    • Remove the one (13.5mm in length) srew holding the power connector and cord in place.
  5. iLive IKBC384S Power cord and connector Replacement: passo 5, immagine 1 di 1
    • Remove the power cord connected to the motherboard.
Conclusione
Allen Dover
Membro da: 03/21/17
401 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 319
