Salta al contenuto principale
iLive IKBC384S Motherboard Replacement
Cosa ti serve
  1. iLive IKBC384S Motherboard Replacement, Top Cover: passo 1, immagine 1 di 2 iLive IKBC384S Motherboard Replacement, Top Cover: passo 1, immagine 2 di 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Motherboard Replacement: passo 2, immagine 1 di 2 iLive IKBC384S Motherboard Replacement: passo 2, immagine 2 di 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Motherboard Replacement: passo 3, immagine 1 di 2 iLive IKBC384S Motherboard Replacement: passo 3, immagine 2 di 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Motherboard Replacement, Motherboard: passo 4, immagine 1 di 1
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  5. iLive IKBC384S Motherboard Replacement: passo 5, immagine 1 di 2 iLive IKBC384S Motherboard Replacement: passo 5, immagine 2 di 2
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Disconnect the two power connectors from the motherboard.
  6. iLive IKBC384S Motherboard Replacement: passo 6, immagine 1 di 1
    • You will need to desolder the antenna.
    • Be sure to desolder the piece connected to the motherboard not the wire.
  7. iLive IKBC384S Motherboard Replacement: passo 7, immagine 1 di 1
    • You will need to remove the speakers and power connector.
    • Once you have removed all of these from the motherboard, the motherboard can be removed
Conclusione
Tracy Walts
Membro da: 03/21/17
201 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 277
