Salta al contenuto principale
iHome iPL8 Buttons Replacement
Cosa ti serve
    1. iHome iPL8  Buttons Replacement, Battery: passo 1, immagine 1 di 1
      • Turn the device over to access the bottom panel.
      • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
      Chiedi a FixBot
      Aggiungi Commento
    2. iHome iPL8  Buttons Replacement: passo 2, immagine 1 di 1
      • Using a Phillips #2 screwdriver, unscrew the captive screw.
      • Keep turning until the screw and the door are loose.
      Chiedi a FixBot
      Aggiungi Commento
    3. iHome iPL8  Buttons Replacement: passo 3, immagine 1 di 1
      • Lift and remove the battery access panel.
      • The captive screw will remain attached to the panel.
      Chiedi a FixBot
      Aggiungi Commento
    4. iHome iPL8  Buttons Replacement: passo 4, immagine 1 di 2 iHome iPL8  Buttons Replacement: passo 4, immagine 2 di 2
      • Gently press on the rim of the 3V battery.
      • Remove the 3V battery.
      Chiedi a FixBot
      Aggiungi Commento
    1. iHome iPL8  Buttons Replacement, Lightning Connector: passo 5, immagine 1 di 1
      • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
      • Remove the four 6mm Phillips #2 screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. iHome iPL8  Buttons Replacement: passo 6, immagine 1 di 1
      • Remove the four round pads from the bottom of the device.
      • There are two additional 6mm Phillips #2 screws under the pads.
      • Using a Phillips #2 screwdriver, remove the two remaining screws.
      • Put your hand on the silver bottom case and gently pull it outward.
      Chiedi a FixBot
      Aggiungi Commento
    3. iHome iPL8  Buttons Replacement: passo 7, immagine 1 di 2 iHome iPL8  Buttons Replacement: passo 7, immagine 2 di 2
      • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
      • Pull out the green circuit board on the two corners.
      • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
      Chiedi a FixBot
      Aggiungi Commento
    4. iHome iPL8  Buttons Replacement: passo 8, immagine 1 di 2 iHome iPL8  Buttons Replacement: passo 8, immagine 2 di 2
      • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
      • Remove the two screws and the black cover.
      • Gently remove the lightning dock assembly.
      • The lightning dock assembly is connected to wires.
      Chiedi a FixBot
      Aggiungi Commento
    5. iHome iPL8  Buttons Replacement: passo 9, immagine 1 di 3 iHome iPL8  Buttons Replacement: passo 9, immagine 2 di 3 iHome iPL8  Buttons Replacement: passo 9, immagine 3 di 3
      • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
      • Remove the back cover.
      • Use your fingers to reposition the lightning connector.
      • Make sure ALL of the lightning connector is exposed.
      Chiedi a FixBot
      Aggiungi Commento
    1. iHome iPL8  Buttons Replacement, Buttons: passo 10, immagine 1 di 3 iHome iPL8  Buttons Replacement, Buttons: passo 10, immagine 2 di 3 iHome iPL8  Buttons Replacement, Buttons: passo 10, immagine 3 di 3
      • Locate the light brown, rectangular button board. Remove the five 2.5 mm Phillips #1 screws, four along the perimeter and one in the center.
      • Remove the brown button board.
      • There is a foam sheet underneath the button board. Use your hand to take it off and put it aside.
      Chiedi a FixBot
      Aggiungi Commento
    2. iHome iPL8  Buttons Replacement: passo 11, immagine 1 di 2 iHome iPL8  Buttons Replacement: passo 11, immagine 2 di 2
      • There are two rows of buttons clipped on to the small, circular, black columns.
      • Gently unclip the two rows of buttons and remove them.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Chen Zhong
Membro da: 02/05/19
569 Reputazione
4 guide realizzate
UC Davis, Team S18-G5, Lore Winter 2019 Membro di UC Davis, Team S18-G5, Lore Winter 2019
UCD-LORE-W19S18G5
3 Membri
8 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 14
Tutti i Tempi: 520
