Salta al contenuto principale
iHome iP21 Docking Station Pin Replacement
Cosa ti serve
  1. iHome iP21 Docking Station Pin Replacement, Base: passo 1, immagine 1 di 3 iHome iP21 Docking Station Pin Replacement, Base: passo 1, immagine 2 di 3 iHome iP21 Docking Station Pin Replacement, Base: passo 1, immagine 3 di 3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Docking Station Pin Replacement, Housing: passo 2, immagine 1 di 2 iHome iP21 Docking Station Pin Replacement, Housing: passo 2, immagine 2 di 2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Docking Station Pin Replacement, 30-pin docking mount: passo 3, immagine 1 di 1
    • Locate the 30-pin docking mount on the iP21. The 30-pin docking mount is visible on top of the iP21.
  4. iHome iP21 Docking Station Pin Replacement, Protective cover: passo 4, immagine 1 di 2 iHome iP21 Docking Station Pin Replacement, Protective cover: passo 4, immagine 2 di 2
    • Remove the four 4mm screws from the protective cover using the iFixit Phillips #1 bit
  5. iHome iP21 Docking Station Pin Replacement, Ribbon cables: passo 5, immagine 1 di 3 iHome iP21 Docking Station Pin Replacement, Ribbon cables: passo 5, immagine 2 di 3 iHome iP21 Docking Station Pin Replacement, Ribbon cables: passo 5, immagine 3 di 3
    • Grasp plastic cable connector ends
    • Remove the mini circuit board with 30-pin mounting dock from the two black plastic pegs.
    • Rock gently back and forth and pull to detach mini circuit board with 30-pin mounting dock attached.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 12
Tutti i Tempi: 723
