Salta al contenuto principale
iHome iP21 Display LED Replacement
Cosa ti serve
  1. iHome iP21 Display LED Replacement, Base: passo 1, immagine 1 di 3 iHome iP21 Display LED Replacement, Base: passo 1, immagine 2 di 3 iHome iP21 Display LED Replacement, Base: passo 1, immagine 3 di 3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Display LED Replacement, Housing: passo 2, immagine 1 di 2 iHome iP21 Display LED Replacement, Housing: passo 2, immagine 2 di 2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Display LED Replacement, Remove Speaker Assembly: passo 3, immagine 1 di 1
    • Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
  4. iHome iP21 Display LED Replacement, Remove speaker from speaker assembly: passo 4, immagine 1 di 2 iHome iP21 Display LED Replacement, Remove speaker from speaker assembly: passo 4, immagine 2 di 2
    • Lift speaker assembly
    • Remove four 7mm screws to detach speaker from speaker assembly
  5. iHome iP21 Display LED Replacement, Display circuit board: passo 5, immagine 1 di 3 iHome iP21 Display LED Replacement, Display circuit board: passo 5, immagine 2 di 3 iHome iP21 Display LED Replacement, Display circuit board: passo 5, immagine 3 di 3
    • Remove six 6mm screws from display circuit board.
    • Press black holding clips down and outward to release display circuit board.
    • Lift display circuit board to detach it from the housing.
  6. iHome iP21 Display LED Replacement, Cables: passo 6, immagine 1 di 2 iHome iP21 Display LED Replacement, Cables: passo 6, immagine 2 di 2
    • Desolder the solder joints connecting the grounding cable to the display circuit board.
    • Remove glue from the ribbon cables with your fingers. Grasp and pull the glue to remove it from the circuit board.
    • Desolder the solder joints connecting the three ribbon cables to the back of the display circuit board.
    • Desolder the solder joints connecting the two grounding cables to the back of the display circuit board.
    • Desolder the solder joints connecting the two grounding cables to the back of the main housing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 310
