Salta al contenuto principale
iHome iH3L Scroll Wheel Circuit Board Replacement
Cosa ti serve
  1. iHome iH3L Scroll Wheel Circuit Board  Replacement, Speakers: passo 1, immagine 1 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement, Speakers: passo 1, immagine 2 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement, Speakers: passo 1, immagine 3 di 3
    • Locate all screws on the back of the iHome. Each screw can be located by the arrows on the iHome.
    • Two Countersunk 9.7 mm Phillips #2 screws in the middle.
    • Two 15.9 mm Phillips #2 screws.
    • Six 13.9 mm Phillips #2 screws.
    • Some screws are located under the black sticky pads. Gently remove the black sticky pads and it will expose the screws.
    • Two 11.8 mm Phillips #2 screws.
  2. iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 2, immagine 1 di 2 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 2, immagine 2 di 2
    • Remove all screws indicated in the previous step.
  3. iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 3, immagine 1 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 3, immagine 2 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 3, immagine 3 di 3
    • Slowly tilt the bottom cover of the iHome up.
    • Do not yank the cover off, there is a wire connecting the cover to the circuit board.
    • Disconnect the wire just by pulling on the connector gently.
  4. iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 4, immagine 1 di 2 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 4, immagine 2 di 2
    • Disconnect the next connector pin after slowly opening the lid more.
  5. iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 5, immagine 1 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 5, immagine 2 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 5, immagine 3 di 3
    • Disconnect the final connector pin series and carefully set your lid behind the body of the iHome.
    • The tiny speaker will not be disconnected for this repair, but you can easily remove it from the lid by means of a paperclip from the outside. While not necessary, this can help prevent damage to your device.
  6. iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 6, immagine 1 di 2 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 6, immagine 2 di 2
    • Remove the seven screws that are holding the motherboard in place:
    • Six 14 mm Phillips #2 screws.
    • One 14 mm Phillips #2 screw with two rubber washers on it.
  7. iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 7, immagine 1 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 7, immagine 2 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 7, immagine 3 di 3
    • To remove the motherboard, gently lift up from opposite sides.
    • Be careful when lifting the motherboard. There are wires still connected to it on the backside.
  8. iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 8, immagine 1 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 8, immagine 2 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 8, immagine 3 di 3
    • Carefully tilt the motherboard up from the front.
    • Disconnect the 8 connections by gently pulling on them. Starting from the front and work your way backwards.
    • All 8 connectors disconnected.
  9. iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 9, immagine 1 di 2 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 9, immagine 2 di 2
    • Unscrew the screws holding the speakers onto the body. One on each side:
    • Two 14.3 mm Phillips #2 screws.
  10. iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 10, immagine 1 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 10, immagine 2 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 10, immagine 3 di 3
    • To remove the speakers from the iHome, gently lift up the back of the speaker and pull towards you. These are very secure so minor shaking may help release the speaker.
    • Repeat for the other side.
    • Be careful yanking on them, the speakers are connected together.
  11. iHome iH3L Scroll Wheel Circuit Board  Replacement, Scroll Wheel Circuit Board: passo 11, immagine 1 di 2 iHome iH3L Scroll Wheel Circuit Board  Replacement, Scroll Wheel Circuit Board: passo 11, immagine 2 di 2
    • Remove the three 7.9 mm Phillips #2 screws holding the scroll wheel board down.
  12. iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 12, immagine 1 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 12, immagine 2 di 3 iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 12, immagine 3 di 3
    • With the screws removed, gently pull the scroll wheel circuit board up.
    • Repeat for the other scroll wheel circuit board.
    • Do not yank it off, the wire will still be connected to it.
  13. iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 13, immagine 1 di 1
    • The connector to the scroll wheel has already been disconnected from the motherboard.
    • Untangling the wires might be necessary to completely remove it.
  14. iHome iH3L Scroll Wheel Circuit Board  Replacement: passo 14, immagine 1 di 1
    • You have successfully removed the scroll wheel circuit boards.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 251
