Salta al contenuto principale
iHome iH27B iPod Adapter Replacement
Cosa ti serve
  1. iHome iH27B iPod Adapter Replacement, Adapter: passo 1, immagine 1 di 1
    • Set the IHome on a surface facing upward.
    • Locate the two screws on the docking station adapter.
    • Remove the following screws:
    • Two 10 mm Phillips #0
  2. iHome iH27B iPod Adapter Replacement: passo 2, immagine 1 di 1
    • Grip the plastic adapter case and pull upwards with a medium amount of force. You will have to twist forward a little so that the connections are visible.
    • The adapter will still be connected with wires, so make sure not to pull too hard.
  3. iHome iH27B iPod Adapter Replacement: passo 3, immagine 1 di 3 iHome iH27B iPod Adapter Replacement: passo 3, immagine 2 di 3 iHome iH27B iPod Adapter Replacement: passo 3, immagine 3 di 3
    • Four 7 mm Phillips #0
    • Lift up the two black plastic pieces that have come loose on either side of the circuit board, and set them aside.
  4. iHome iH27B iPod Adapter Replacement: passo 4, immagine 1 di 2 iHome iH27B iPod Adapter Replacement: passo 4, immagine 2 di 2
    • Carefully pry apart the bundle of white wires connected at the junction with the plastic opening tool.
    • Do this slowly. Be careful not to damage the wires
    • Lift up the circuit board that has become loose.
  5. iHome iH27B iPod Adapter Replacement: passo 5, immagine 1 di 1
    • Pull out the adapter, and replace it with the new one.
Conclusione
Cal Poly, Team 3-21, Amido Fall 2012 Membro di Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,324
