Salta al contenuto principale
iHome iH27B Daylight Savings Switch Replacement
Cosa ti serve
  1. iHome iH27B Daylight Savings Switch Replacement, Outer Case: passo 1, immagine 1 di 1
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. iHome iH27B Daylight Savings Switch Replacement: passo 2, immagine 1 di 3 iHome iH27B Daylight Savings Switch Replacement: passo 2, immagine 2 di 3 iHome iH27B Daylight Savings Switch Replacement: passo 2, immagine 3 di 3
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Set the plastic covering and the watch battery aside.
  3. iHome iH27B Daylight Savings Switch Replacement: passo 3, immagine 1 di 1
    • Remove the following screws:
    • Eight 10 mm using the Phillips #0 on the bottom of your device.
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. iHome iH27B Daylight Savings Switch Replacement: passo 4, immagine 1 di 1
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  5. iHome iH27B Daylight Savings Switch Replacement: passo 5, immagine 1 di 1
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
  6. iHome iH27B Daylight Savings Switch Replacement, Daylight Savings Switch: passo 6, immagine 1 di 1
    • Two 10 mm Phillips #0
  7. iHome iH27B Daylight Savings Switch Replacement: passo 7, immagine 1 di 1
    • Remove switch and replace with new one.
Conclusione
John Kraemer
Membro da: 10/09/12
76 Reputazione
9 Guide realizzate
Cal Poly, Team 3-21, Amido Fall 2012 Membro di Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 721
