Salta al contenuto principale
iHome iD95 Speakers Replacement
Cosa ti serve
  1. iHome iD95 Speakers Replacement, Backup Battery: passo 1, immagine 1 di 1
    • Before taking apart the iD95, disconnect the AC cord from the wall socket and AC adapter from the DC jack. Remove any iPods, iPhones, and iPads attached to the device.
    • Flip over the iD95 so the bottom cover is visible and the LCD screen is facing you.
  2. iHome iD95 Speakers Replacement: passo 2, immagine 1 di 1
    • Remove the 10 mm-length, 5 mm-head screw using a Phillips #1 screwdriver.
  3. iHome iD95 Speakers Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to take out the backup battery.
  4. iHome iD95 Speakers Replacement, Bottom Cover: passo 4, immagine 1 di 1
    • Unscrew five 17 mm-length, 6 mm-head screws using a Phillips #1 screwdriver.
  5. iHome iD95 Speakers Replacement: passo 5, immagine 1 di 2 iHome iD95 Speakers Replacement: passo 5, immagine 2 di 2
    • The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force.
    • Insert a plastic opening tool between the edge of the bottom cover and the main body.
    • Gently pry the bottom cover from the body. Start anywhere along the front side of the iD95 and work your way around.
    • Grip the bottom portion of the device and gently lift the front part of the bottom cover a couple centimeters up.
  6. iHome iD95 Speakers Replacement: passo 6, immagine 1 di 2 iHome iD95 Speakers Replacement: passo 6, immagine 2 di 2
    • Potential for device damage: Be careful not to use too much force or you might break the plastic rings holding the side panels in place.
    • Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
    • The side panels have plastic rings that will need to be lifted up and off the cylinders they are placed around.
  7. iHome iD95 Speakers Replacement: passo 7, immagine 1 di 2 iHome iD95 Speakers Replacement: passo 7, immagine 2 di 2
    • Apply the same techniques from the previous step to remove the remaining side panel.
  8. iHome iD95 Speakers Replacement: passo 8, immagine 1 di 3 iHome iD95 Speakers Replacement: passo 8, immagine 2 di 3 iHome iD95 Speakers Replacement: passo 8, immagine 3 di 3
    • Locate the two plastic clips holding the bottom and back cover together.
    • Which clip you remove first is up to you. Rotate the device 90 degrees either left or right. Insert the flat end of a spudger horizontally between the back speaker and the back cover.
    • Place the flat end of the spudger behind one clip and pry it open. This may take repeated attempts.
    • This is the hardest step because the angle is awkward and the visibility is poor. If possible, have someone hold the device or provide lighting.
    • Once a clip has been removed, hold the bottom cover open so the clip will not fall back into place. One clip remains to be removed; you are almost there!
  9. iHome iD95 Speakers Replacement: passo 9, immagine 1 di 2 iHome iD95 Speakers Replacement: passo 9, immagine 2 di 2
    • Use the same steps to remove the remaining clip.
    • The bottom cover is still connected to the motherboard by wiring.
  10. iHome iD95 Speakers Replacement: passo 10, immagine 1 di 2 iHome iD95 Speakers Replacement: passo 10, immagine 2 di 2
    • Use a plastic opening tool to pry off the white ZIF connector joining the wires to the motherboard.
    • Don't pull the wires. Take your time using a plastic opening tool.
  11. iHome iD95 Speakers Replacement, Speakers: passo 11, immagine 1 di 1
    • Take out four 14 mm screws using a Phillips #1 screwdriver.
  12. iHome iD95 Speakers Replacement: passo 12, immagine 1 di 3 iHome iD95 Speakers Replacement: passo 12, immagine 2 di 3 iHome iD95 Speakers Replacement: passo 12, immagine 3 di 3
    • Use a plastic opening tool to lift the two speaker zip connectors from the logic board.
    • Do not pull on the speaker wires directly. Continue to use a plastic opening tool.
  13. iHome iD95 Speakers Replacement: passo 13, immagine 1 di 1
    • Lift and remove both speakers.
Conclusione
Altre 2 persone hanno completato questa guida.
Craig Cary
Membro da: 04/18/13
52 Reputazione
1 Guida realizzata
Cal Poly, Team 12-37, Amido Spring 2013 Membro di Cal Poly, Team 12-37, Amido Spring 2013
CPSU-AMIDO-S13S12G37
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 905
