Salta al contenuto principale
iHome iBT16 Base Plate Replacement
Cosa ti serve
  1. iHome iBT16 Base Plate Replacement, Base Plate: passo 1, immagine 1 di 2 iHome iBT16 Base Plate Replacement, Base Plate: passo 1, immagine 2 di 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Base Plate Replacement: passo 2, immagine 1 di 2 iHome iBT16 Base Plate Replacement: passo 2, immagine 2 di 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
Conclusione
Ryan Edwards
Membro da: 03/21/17
331 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 229
