Salta al contenuto principale
iHome iAVS16 LCD (Display) Replacement
Cosa ti serve
  1. iHome iAVS16 LCD (Display) Replacement, Power Board: passo 1, immagine 1 di 3 iHome iAVS16 LCD (Display) Replacement, Power Board: passo 1, immagine 2 di 3 iHome iAVS16 LCD (Display) Replacement, Power Board: passo 1, immagine 3 di 3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 LCD (Display) Replacement: passo 2, immagine 1 di 3 iHome iAVS16 LCD (Display) Replacement: passo 2, immagine 2 di 3 iHome iAVS16 LCD (Display) Replacement: passo 2, immagine 3 di 3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 LCD (Display) Replacement: passo 3, immagine 1 di 2 iHome iAVS16 LCD (Display) Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 LCD (Display) Replacement: passo 4, immagine 1 di 3 iHome iAVS16 LCD (Display) Replacement: passo 4, immagine 2 di 3 iHome iAVS16 LCD (Display) Replacement: passo 4, immagine 3 di 3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 LCD (Display) Replacement, LCD (Display): passo 5, immagine 1 di 3 iHome iAVS16 LCD (Display) Replacement, LCD (Display): passo 5, immagine 2 di 3 iHome iAVS16 LCD (Display) Replacement, LCD (Display): passo 5, immagine 3 di 3
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 LCD (Display) Replacement: passo 6, immagine 1 di 1
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 LCD (Display) Replacement: passo 7, immagine 1 di 3 iHome iAVS16 LCD (Display) Replacement: passo 7, immagine 2 di 3 iHome iAVS16 LCD (Display) Replacement: passo 7, immagine 3 di 3
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
Conclusione
Marco Sousa
Membro da: 10/25/19
293 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 204
