Salta al contenuto principale
iHome IH11 Dock Connector Replacement
Cosa ti serve
  1. iHome IH11 Dock Connector Replacement, Dock Connector: passo 1, immagine 1 di 1
    • Remove the two 9mm screws that hold on the dock connector with a Phillips #1 Screwdriver.
  2. iHome IH11 Dock Connector Replacement: passo 2, immagine 1 di 2 iHome IH11 Dock Connector Replacement: passo 2, immagine 2 di 2
    • Pop the dock connector out of the iHome and gently pull the white plastic plug connected to the dock connector apart.
    • Remove the four 7.0mm screws with a Phillips #1 screwdriver.
  3. iHome IH11 Dock Connector Replacement: passo 3, immagine 1 di 1
    • Remove both of the black plastic pieces. They should easily slide off of the two guide holes in the circuit board.
    • The dock connector should now be exposed. You can now simply put your new dock connector in the old one's place.
    Where can. I find the. Pin out. For this. Connector
    Roy H - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
Nick Knowles
Membro da: 04/19/13
21 Reputazione
2 Guide realizzate
Cal Poly, Team 14-9, Maness Spring 2013 Membro di Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Membri
5 Guide realizzate
2 Commenti
Where can I buy a replacement dock connector?
A Ross - Replica
Likewise, this guide isn't much good if it uses parts that are unavailable.
CJ Shumate - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,392
