Salta al contenuto principale
iHome IBT16 Micro USB port Replacement
Cosa ti serve
  1. iHome IBT16 Micro USB port Replacement, Base Plate: passo 1, immagine 1 di 2 iHome IBT16 Micro USB port Replacement, Base Plate: passo 1, immagine 2 di 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome IBT16 Micro USB port Replacement: passo 2, immagine 1 di 2 iHome IBT16 Micro USB port Replacement: passo 2, immagine 2 di 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome IBT16 Micro USB port Replacement, Micro USB port: passo 3, immagine 1 di 1
    • Inside the iHome remove the two silver Phillips screws that are on the motherboard.
    • Connect the ground strap to ground, and then put the strap around your wrist.
  4. iHome IBT16 Micro USB port Replacement: passo 4, immagine 1 di 1
    • Take the motherboard out of the device, use the plastic opening tool to ensure the power switch doesn't get stuck.
  5. iHome IBT16 Micro USB port Replacement: passo 5, immagine 1 di 1
    • On the other side of the motherboard unsolder the two biggest solder joints under the micro USB.
  6. iHome IBT16 Micro USB port Replacement: passo 6, immagine 1 di 1
    • On the side of the motherboard that the micro USB connector is there are five surface mount solder joints at the back of the connector. Unsolder these five solder joints.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,468
