Salta al contenuto principale
iHip Fold-up Portable Speaker iPod/iPhone Input Replacement
Cosa ti serve
  1. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing the battery case cover: passo 1, immagine 1 di 1
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Cleaning the battery case: passo 2, immagine 1 di 3 iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Cleaning the battery case: passo 2, immagine 2 di 3 iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Cleaning the battery case: passo 2, immagine 3 di 3
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing the screws: passo 3, immagine 1 di 2 iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing the screws: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing the back cover: passo 4, immagine 1 di 2 iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing the back cover: passo 4, immagine 2 di 2
    • Remove the back cover carefully; there are many wires that connect it to the device.
  5. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Taking out the iPod/iPhone input: passo 5, immagine 1 di 2 iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Taking out the iPod/iPhone input: passo 5, immagine 2 di 2
    • Locate the iPhone/iPod input that is in the center of the console.
    • Push the black plastic input stand to the left, and up, with your index finger.
    • Use tweezers to wedge the input stand out of its slot.
  6. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing iPod/iPhone Input: passo 6, immagine 1 di 1
    • Pull out the iPod/iPhone input with tweezers.
  7. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Removing the Line In Chip: passo 7, immagine 1 di 1
    • Gently remove the Line In chip with tweezers.
    • Note: The Line In chip is located on the left side of the device.
  8. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Cutting the Input Wires from the Line In Chip: passo 8, immagine 1 di 1
    • Use scissors to cut the black, yellow, and red wires that connect the Line In chip to the iPod/iPhone input.
    • Remove the old iPod/iPhone input and its associated wires.
  9. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Cauterizing the New Input Wires to the Line In Chip: passo 9, immagine 1 di 1
    Desoldering Pump
    $3.99
    • Follow the instructions provided with the soldering station to preheat the gun before use.
    • Place new iPod/iPhone input wires, one by one, in their previous position on the Line In chip. Wrap a strip of soldering wire on the point of contact between the chip and input wire.
    • Use the soldering gun to melt the strip of soldering wire.
  10. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Replacing the Line In Chip: passo 10, immagine 1 di 1
    • Use tweezers to carefully place the newly soldered Line In chip back into its original position.
  11. iHip Fold-up Portable Speaker iPod/iPhone Input Replacement, Positioning New iPod/iPhone Input Into Original Position: passo 11, immagine 1 di 1
    • With tweezers, insert the end of the iPod/iPhone input through its designated hole.
    • Note: The device has been rotated 90 degrees to the left in this picture.
    • With both thumbs, push in the black plastic input stand until it snaps into place.
Conclusione
Clemson, Team 3-4, Benson Fall 2014 Membro di Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 23
Tutti i Tempi: 287
