Salta al contenuto principale
iHip Fold-Up Portable Speaker Stand Replacement
Cosa ti serve
  1. iHip Fold-Up Portable Speaker Stand Replacement, Removing the battery case cover: passo 1, immagine 1 di 1
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-Up Portable Speaker Stand Replacement, Cleaning the battery case: passo 2, immagine 1 di 3 iHip Fold-Up Portable Speaker Stand Replacement, Cleaning the battery case: passo 2, immagine 2 di 3 iHip Fold-Up Portable Speaker Stand Replacement, Cleaning the battery case: passo 2, immagine 3 di 3
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-Up Portable Speaker Stand Replacement, Removing the screws: passo 3, immagine 1 di 2 iHip Fold-Up Portable Speaker Stand Replacement, Removing the screws: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-Up Portable Speaker Stand Replacement, Removing the back cover: passo 4, immagine 1 di 2 iHip Fold-Up Portable Speaker Stand Replacement, Removing the back cover: passo 4, immagine 2 di 2
    • Remove the back cover carefully; there are many wires that connect it to the device.
  5. iHip Fold-Up Portable Speaker Stand Replacement, Positioning the Stand: passo 5, immagine 1 di 1
    • Pull the stand backwards and around the system.
    • Make sure the stand is positioned perpendicular to the speaker system.
  6. iHip Fold-Up Portable Speaker Stand Replacement, Removing the Stand: passo 6, immagine 1 di 2 iHip Fold-Up Portable Speaker Stand Replacement, Removing the Stand: passo 6, immagine 2 di 2
    • Locate the two small connection points for the stand.
    • Using small needle nose pliers, pinch the end of the stand toward the side of the speaker case.
    • Pop the end of the stand out of the hole in the side of the speaker case.
    • Repeat this step for the opposite side of the stand.
  7. iHip Fold-Up Portable Speaker Stand Replacement, Connecting The New Stand: passo 7, immagine 1 di 1
    • 1. Position the new stand perpendicular to the speaker case.
    • 2. Align the bulbs at the end of the stand with the holes in the side of the speaker case.
    • 3. Gently push the bulbs into the holes of the speaker case.
    • 4. Pull the stand back around the speaker system.
Conclusione
Lisa
Membro da: 10/13/14
207 Reputazione
2 Guide realizzate
Clemson, Team 3-4, Benson Fall 2014 Membro di Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 251
