Salta al contenuto principale
iHealth Edge Battery Replacement
Cosa ti serve
  1. iHealth Edge Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Lightly heat device with hair dryer for 15 seconds to soften adhesive.
  2. iHealth Edge Battery Replacement: passo 2, immagine 1 di 1
    • After heating adhesive, firmly pry apart the two halves.
  3. iHealth Edge Battery Replacement: passo 3, immagine 1 di 1
    • Remove polymer cover that is protecting the mother board, it should just come out when two halves are separated.
  4. iHealth Edge Battery Replacement: passo 4, immagine 1 di 1
    • Use a spudger or plastic opening tool to assist the removal of the motherboard. Pry up on two tabs and the mother board will pop out.
  5. iHealth Edge Battery Replacement: passo 5, immagine 1 di 1
    • This shows the mother board and battery out and exposed.
  6. iHealth Edge Battery Replacement: passo 6, immagine 1 di 1
    • You must remove the solder from two wires from the motherboard that are connected to the battery.
Conclusione
IUPUI, Team S1-G4, Freund Fall 2017 Membro di IUPUI, Team S1-G4, Freund Fall 2017
IUPUI-FREUND-F17S1G4
4 Membri
3 Guide realizzate
Un commento
where can I buy the new battery?? or what are the characteristics of the battery?
Fafi Dau - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,403
