Salta al contenuto principale
iHealth Edge Band Replacement
  1. iHealth Edge Band Replacement, Band: passo 1, immagine 1 di 1
    • Pull the elastic band away from the device as shown. You will need to use one hand to support the device and pull the elastic band with the other at about a 45 degree angle.
  2. iHealth Edge Band Replacement: passo 2, immagine 1 di 1
    • Pull the elastic band away from the device, you should now have the device with no band as shown.
  3. iHealth Edge Band Replacement: passo 3, immagine 1 di 2 iHealth Edge Band Replacement: passo 3, immagine 2 di 2
    • Place the elastic band into the channel in the side of the device shown in the picture. The band will pull into the channel and lock into place.
  4. iHealth Edge Band Replacement: passo 4, immagine 1 di 1
    • After pulling the band into place the guide is now complete. Your iHealth Edge should be ready for use.
Conclusione
This guide will show you how to replace the arm band.
IUPUI, Team S1-G4, Freund Fall 2017 Membro di IUPUI, Team S1-G4, Freund Fall 2017
IUPUI-FREUND-F17S1G4
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 378
