Salta al contenuto principale
iDevices iGrill Probe Replacement
Cosa ti serve
  1. iDevices iGrill Probe Replacement, Probes: passo 1, immagine 1 di 1
    • Remove the back plastic cover from the device; this should allow you access to the batteries.
  2. iDevices iGrill Probe Replacement: passo 2, immagine 1 di 1
    • Remove the batteries from the device.
  3. iDevices iGrill Probe Replacement: passo 3, immagine 1 di 2 iDevices iGrill Probe Replacement: passo 3, immagine 2 di 2
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm screws using a Phillips screwdriver. The screws are located on the left side of the internal cover.
    • Remove the accompanying plastic tabs under the screws.
    • Gently pull off the back cover from the device.
  4. iDevices iGrill Probe Replacement: passo 4, immagine 1 di 3 iDevices iGrill Probe Replacement: passo 4, immagine 2 di 3 iDevices iGrill Probe Replacement: passo 4, immagine 3 di 3
    • If you have not removed the 2 silver-colored screws; you must remove them now.
    • Remove the metal terminals from the battery slot closest you.
    • Pull the remaining metal terminals out of their slots. Position them such that when removing the internal cover they will not be caught.
    • Remove the internal cover.
  5. iDevices iGrill Probe Replacement: passo 5, immagine 1 di 1
    • After the internal plastic case has been removed, you will have access to the probe contacts.
    • You should then insert the probes to check their connection to the probe terminals.
  6. iDevices iGrill Probe Replacement: passo 6, immagine 1 di 1
    • Using a pair of tweezers, bend the probe contacts back in place. The tweezers will touch the probe terminals when inserted.
Conclusione
IUPUI, Team 3-4, Harley Spring 2016 Membro di IUPUI, Team 3-4, Harley Spring 2016
IUPUI-HARLEY-S16S3G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,047
