Salta al contenuto principale
iDevices iGrill Power Delivery Wires and Springs Replacement
Cosa ti serve
  1. iDevices iGrill Power Delivery Wires and Springs Replacement, Power Delivery Wires and Springs: passo 1, immagine 1 di 1
    • Place the front screen of the device on a flat surface, this allows access to the back cover. Remove the back cover from the device to access the batteries.
  2. iDevices iGrill Power Delivery Wires and Springs Replacement: passo 2, immagine 1 di 1
    • Remove the batteries from the device, allowing you to access the screws necessary for removal of the back panel.
  3. iDevices iGrill Power Delivery Wires and Springs Replacement: passo 3, immagine 1 di 2 iDevices iGrill Power Delivery Wires and Springs Replacement: passo 3, immagine 2 di 2
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm Phillips screws from the left side of the internal cover.
  4. iDevices iGrill Power Delivery Wires and Springs Replacement: passo 4, immagine 1 di 1
    • Gently and slowly pull the back cover off of the iGrill, exposing the power cables to the motherboard.
  5. iDevices iGrill Power Delivery Wires and Springs Replacement: passo 5, immagine 1 di 2 iDevices iGrill Power Delivery Wires and Springs Replacement: passo 5, immagine 2 di 2
    • Gently pull the metal terminals to the batteries out of their plastic holders.
    • Position the metal terminals such that you will be able to pull the plastic component that holds the batteries away from the motherboard.
    • Remove the internal cover from the device.
  6. iDevices iGrill Power Delivery Wires and Springs Replacement: passo 6, immagine 1 di 1
    • After you have peeled back the rear plastic covering, you will have access to the motherboard.
  7. iDevices iGrill Power Delivery Wires and Springs Replacement: passo 7, immagine 1 di 1
    • From here, you will have access to both the metal terminals of the power transfer wires and the soldering points of the power transfer wires to the motherboard.
    • If any of these connections have been broken, repair them with a solder and soldering wire.
Conclusione
Kyle McElyea
Membro da: 02/16/16
259 Reputazione
2 Guide realizzate
IUPUI, Team 3-4, Harley Spring 2016 Membro di IUPUI, Team 3-4, Harley Spring 2016
IUPUI-HARLEY-S16S3G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 289
