Salta al contenuto principale
iDeaUSA CT8 Power Button Replacement
Cosa ti serve
  1. iDeaUSA CT8 Power Button Replacement, Power Button: passo 1, immagine 1 di 3 iDeaUSA CT8 Power Button Replacement, Power Button: passo 1, immagine 2 di 3 iDeaUSA CT8 Power Button Replacement, Power Button: passo 1, immagine 3 di 3
    • Place the tablet on a flat surface, facing upwards.
    • Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
    • Being cautious of the wire connecting the speaker and the motherboard, place the front and back portion of the tablet close in proximity.
  2. iDeaUSA CT8 Power Button Replacement: passo 2, immagine 1 di 2 iDeaUSA CT8 Power Button Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • On the tablet’s back cover, locate the power button.
    • Use tweezers to remove button’s padding that holds it in place.
  3. iDeaUSA CT8 Power Button Replacement: passo 3, immagine 1 di 1
    • To remove the power button, use a plastic opening tool to nudge the button out of position.
    • A gentle push from the button’s exterior side should be enough.
  4. iDeaUSA CT8 Power Button Replacement: passo 4, immagine 1 di 1
    • The power button is now removed. Adjust accordingly or replace it
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 103
