Introduzione
In cases where the device is not responding, this guide will help you replace the motherboard.
Cosa ti serve
Place the tablet on a flat surface, facing upwards.
Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
Being cautious of the wire connecting the speaker and the motherboard, place the front and back portion of the tablet close in proximity.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
After removing the tape, two blue ribbon wires can now be accessed. To disconnect, gently lift up the plastic ZIF tabs covering the wires.
Upon lifting the tab, the ribbons can now be safely pulled out of their connections.
