Salta al contenuto principale
iDea USA CT702 Microphone Replacement
Cosa ti serve
  1. iDea USA CT702 Microphone Replacement, Microphone: passo 1, immagine 1 di 1
    • Place the tablet face up with portholes facing you.
  2. iDea USA CT702 Microphone Replacement: passo 2, immagine 1 di 2 iDea USA CT702 Microphone Replacement: passo 2, immagine 2 di 2
    • Use a fingernail, or a plastic opening tool to gently pry the black panel around the portholes.
    • Be gentle and take your time. Excessive force could damage the device.
  3. iDea USA CT702 Microphone Replacement: passo 3, immagine 1 di 3 iDea USA CT702 Microphone Replacement: passo 3, immagine 2 di 3 iDea USA CT702 Microphone Replacement: passo 3, immagine 3 di 3
    • Use your fingers to pry the rest of the back off; slowly apply pressure from each side to break each clip connection.
  4. iDea USA CT702 Microphone Replacement: passo 4, immagine 1 di 1
    • Once the back is off, position the tablet as shown and be sure to warm your soldering iron.
  5. iDea USA CT702 Microphone Replacement: passo 5, immagine 1 di 1
    • Place tip of the soldering iron on the end of the wire to break connection.
    • Remember to use proper safety precautions when soldering.
  6. iDea USA CT702 Microphone Replacement: passo 6, immagine 1 di 1
    • Grip the new microphone with tweezers and place in the slot.
    • Solder the new connections while using tweezers to hold the speaker steady.
Conclusione
Benton Gray
Membro da: 03/11/15
201 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 111
