Salta al contenuto principale
Introduzione
This guide is an internal prerequisite that should remain unpublished.
Ricambi
Nessuna parte specificata.
  1. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement, Rear Display Bezel: passo 1, immagine 1 di 1
    • Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  2. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: passo 2, immagine 1 di 1
    • Use your thumbs to slightly separate the rear bezel from the front bezel.
    • It is helpful to hold the opposing corner of the display stationary to aid in flexing the rear bezel away from the display.
  3. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: passo 3, immagine 1 di 3 iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: passo 3, immagine 2 di 3 iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: passo 3, immagine 3 di 3
    • Insert the flat end of a spudger into the gap between the front and rear bezels.
    • Rotate your spudger until it is parallel to the front face of the display.
    • Run the spudger around the perimeter of the display to separate the rear bezel from its retaining clips.
  4. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: passo 4, immagine 1 di 1
    • Lift the rear bezel off the display.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 19
Tutti i Tempi: 472
