Introduzione
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Close the display and flip the computer over.
Remove the three hex screws using a T8 Torx screwdriver.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
Altre 2 persone hanno completato questa guida.
