Introduzione
One RAM slot will accept PC2700 chips up to 1 GB.
Cosa ti serve
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the chip directly out from its connectors.
Altre 38 persone hanno completato questa guida.
Documenti Allegati
2 Commenti
Easy-to-follow instructions. I used them to add 1GB RAM to my iBook G4. Thanks to your instructions, I was able to do the job myself. After contacting three Mac repair shops and either not having anyone call me back or else offering to do it for $40 or $109 at a specialty place, I decided to trust your guide and do it myself. Success!
What ya download
Ibrahim -
