Salta al contenuto principale
iBook G3 Clamshell CD Faceplate Replacement
Cosa ti serve
  1. iBook G3 Clamshell CD Faceplate Replacement, Battery: passo 1, immagine 1 di 1
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
  2. iBook G3 Clamshell CD Faceplate Replacement, CD Faceplate: passo 2, immagine 1 di 1
    • Use a straightened paperclip to manually eject the CD-ROM tray.
  3. iBook G3 Clamshell CD Faceplate Replacement: passo 3, immagine 1 di 1
    • Remove the single black Phillips screw from the center of the CD-ROM bezel.
  4. iBook G3 Clamshell CD Faceplate Replacement: passo 4, immagine 1 di 1
    • Grasp the CD-ROM bezel and rotate it upward to remove it from the drive.
Conclusione
Altre 6 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
2 Commenti
There are two small black phillips screws which ALSO need to be removed ...... on some models. Although appearing identical, these covers are "similar" but NOT interchangeable between models of CD-Rom.
John Foster - Replica
Help I've broke my drive cover and it won't go back on how do I fix that
Mr. Yee Macinuwm - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 10,046
