Salta al contenuto principale
iBook G3 14" Airport Card Replacement
Cosa ti serve
  1. iBook G3 14" Airport Card Replacement, Battery: passo 1, immagine 1 di 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G3 14" Airport Card Replacement, Airport Card: passo 2, immagine 1 di 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G3 14" Airport Card Replacement: passo 3, immagine 1 di 1
    • If your computer does not have an Airport card installed, skip to the RAM shield removal step.
    • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
  4. iBook G3 14" Airport Card Replacement: passo 4, immagine 1 di 1
    • Grasp the clear plastic tab on the Airport card and pull toward the right.
  5. iBook G3 14" Airport Card Replacement: passo 5, immagine 1 di 1
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
Conclusione
Altre 3 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 8,024
