Introduzione
If all else has failed, now is the time to replace your motherboard in a last attempt to save your laptop.
Cosa ti serve
Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
Use a spudger to lift the latch that holds the hard drive cable in place.
Altre 2 persone hanno completato questa guida.
2 Commenti
Good job Stephany. I would’ve been lost without you…
your friend eternally,
Richey Dale
How can i get this model motherboard
