Salta al contenuto principale
hp pavilion 15-cc023cl Motherboard Replacement
Cosa ti serve
  1. hp pavilion 15-cc023cl Motherboard Replacement, Battery: passo 1, immagine 1 di 2 hp pavilion 15-cc023cl Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. hp pavilion 15-cc023cl Motherboard Replacement: passo 2, immagine 1 di 1
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. hp pavilion 15-cc023cl Motherboard Replacement: passo 3, immagine 1 di 2 hp pavilion 15-cc023cl Motherboard Replacement: passo 3, immagine 2 di 2
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. hp pavilion 15-cc023cl Motherboard Replacement: passo 4, immagine 1 di 2 hp pavilion 15-cc023cl Motherboard Replacement: passo 4, immagine 2 di 2
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. hp pavilion 15-cc023cl Motherboard Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. hp pavilion 15-cc023cl Motherboard Replacement: passo 6, immagine 1 di 1
    • Use a plastic opening tool to pry the hard drive out.
  7. hp pavilion 15-cc023cl Motherboard Replacement: passo 7, immagine 1 di 1
    • Disconnect the hard drive cable.
  8. hp pavilion 15-cc023cl Motherboard Replacement: passo 8, immagine 1 di 1
    • Lift the plastic wedges up on both sides of the hard drive.
  9. hp pavilion 15-cc023cl Motherboard Replacement, Motherboard: passo 9, immagine 1 di 1
    • Locate the motherboard.
  10. hp pavilion 15-cc023cl Motherboard Replacement: passo 10, immagine 1 di 2 hp pavilion 15-cc023cl Motherboard Replacement: passo 10, immagine 2 di 2
    • Use a PH0 screwdriver to unscrew the three 3 mm Phillips head screws located on the fan.
  11. hp pavilion 15-cc023cl Motherboard Replacement: passo 11, immagine 1 di 1
    • Use a PH1 screwdriver to unscrew the four 3mm Phillips head screws located on the processor cover.
    • Disconnect the cable.
  12. hp pavilion 15-cc023cl Motherboard Replacement: passo 12, immagine 1 di 1
    • Disconnect the plastic arm attached to the processor and remove.
    • Disconnect the cable attaching the fan to the motherboard and remove.
  13. hp pavilion 15-cc023cl Motherboard Replacement: passo 13, immagine 1 di 1
    • Use a PH1 screwdriver to unscrew one 3mm Phillips head screws on Wifi card.
    • Disconnect the Wifi card.
    • Be careful not to break any of the connectors.
  14. hp pavilion 15-cc023cl Motherboard Replacement: passo 14, immagine 1 di 3 hp pavilion 15-cc023cl Motherboard Replacement: passo 14, immagine 2 di 3 hp pavilion 15-cc023cl Motherboard Replacement: passo 14, immagine 3 di 3
    • Disconnect the 5 cables to keyboard and speakers.
    • You may have to pry some up with the spudger.
  15. hp pavilion 15-cc023cl Motherboard Replacement: passo 15, immagine 1 di 2 hp pavilion 15-cc023cl Motherboard Replacement: passo 15, immagine 2 di 2
    • Use a PH1 screwdriver to unscrew six 3 mm Phillips head screws on the motherboard.
  16. hp pavilion 15-cc023cl Motherboard Replacement: passo 16, immagine 1 di 1
    • Use the iFixit opening tools to pry motherboard from back of laptop.
  17. hp pavilion 15-cc023cl Motherboard Replacement: passo 17, immagine 1 di 1
    • Disconnect SD and USB card cable.
Conclusione
Altre 2 persone hanno completato questa guida.
2 Commenti
Good job Stephany. I would’ve been lost without you…
your friend eternally,
Richey Dale
richeydale67 - Replica
How can i get this model motherboard
Adeyinka Alasi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,415
