Salta al contenuto principale
eufy Security SpaceView Monitor Screen Replacement
Cosa ti serve
  1. eufy Security SpaceView Monitor Screen Replacement, Display Assembly: passo 1, immagine 1 di 2 eufy Security SpaceView Monitor Screen Replacement, Display Assembly: passo 1, immagine 2 di 2
    • Use an opening tool to press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
  2. eufy Security SpaceView Monitor Screen Replacement, Lift the display: passo 2, immagine 1 di 1
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
  3. eufy Security SpaceView Monitor Screen Replacement, Screen: passo 3, immagine 1 di 1
    • Lay the display face down on a table, to expose the back of the screen.
    • Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
    • There are two on each end of the display, and one on each of its longer sides.
  4. eufy Security SpaceView Monitor Screen Replacement: passo 4, immagine 1 di 2 eufy Security SpaceView Monitor Screen Replacement: passo 4, immagine 2 di 2
    • Gently lift the display housing, and set it aside.
    • The housing is ready to have the new display installed.
  5. eufy Security SpaceView Monitor Screen Replacement: passo 5, immagine 1 di 1
    • Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
Conclusione
ZFarley
Membro da: 10/31/23
422 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 Membro di UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G5
3 Membri
12 Guide realizzate
2Commenti sulla guida
Where do you get the replacement screen?
Ronald - Replica
Yes please, where do we get a replacement screen, does it come with a ribbon cable? What is the part number?
Laguna - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 134
Tutti i Tempi: 1,818
