Salta al contenuto principale
eufy Security SpaceView Monitor Display Assembly
Cosa ti serve
  1. eufy Security SpaceView Monitor Display Assembly, Display Assembly: passo 1, immagine 1 di 2 eufy Security SpaceView Monitor Display Assembly, Display Assembly: passo 1, immagine 2 di 2
    • Use an opening tool to press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
  2. eufy Security SpaceView Monitor Display Assembly, Lift the display: passo 2, immagine 1 di 1
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
Conclusione
To reassemble, lay the display in its original orientation on top of the housing, and apply even force to the edges of the display. It should click each time, and securely itself tightly to the housing.
ZFarley
Membro da: 10/31/23
395 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 357
