Salta al contenuto principale
eufy RoboVac 11 Rolling Brush Replacement
Cosa ti serve
  1. eufy RoboVac 11 Rolling Brush Replacement, Front Cover and Motherboard: passo 1, immagine 1 di 2 eufy RoboVac 11 Rolling Brush Replacement, Front Cover and Motherboard: passo 1, immagine 2 di 2
    • Remove the nine 10 mm screws with the Phillips #1 precision screwdriver.
    • Keep track of these screws. They are the same length as the interior screws but wider in diameter.
  2. eufy RoboVac 11 Rolling Brush Replacement: passo 2, immagine 1 di 2 eufy RoboVac 11 Rolling Brush Replacement: passo 2, immagine 2 di 2
    • Remove the six 7 mm screws on the bumper with the Phillips #1 screwdriver.
  3. eufy RoboVac 11 Rolling Brush Replacement: passo 3, immagine 1 di 3 eufy RoboVac 11 Rolling Brush Replacement: passo 3, immagine 2 di 3 eufy RoboVac 11 Rolling Brush Replacement: passo 3, immagine 3 di 3
    • Remove the top plate from the body of the device.
    • Unplug the bumper from the motherboard.
  4. eufy RoboVac 11 Rolling Brush Replacement: passo 4, immagine 1 di 2 eufy RoboVac 11 Rolling Brush Replacement: passo 4, immagine 2 di 2
    • Remove the three 10 mm motherboard screws with a Phillips #1 screwdriver.
    • Cleaning the motherboard and inside of the device outdoors with a compressed air cleaner will help the robot last longer.
  5. eufy RoboVac 11 Rolling Brush Replacement: passo 5, immagine 1 di 2 eufy RoboVac 11 Rolling Brush Replacement: passo 5, immagine 2 di 2
    • Unplug the cables from the motherboard.
  6. eufy RoboVac 11 Rolling Brush Replacement, Rolling Brush: passo 6, immagine 1 di 2 eufy RoboVac 11 Rolling Brush Replacement, Rolling Brush: passo 6, immagine 2 di 2
    • Remove the single 10 mm screw with the Phillips #1 screwdriver.
    • Remove the rolling brush.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 42
Tutti i Tempi: 1,461
