Salta al contenuto principale
eufy Clean RoboVac G32 Pro Wheel Replacement
Cosa ti serve
  1. eufy Clean RoboVac G32 Pro Wheel Replacement, Wheel: passo 1, immagine 1 di 1
    • Make sure your device is turned off.
    • Flip the device upside down on a flat surface.
  2. eufy Clean RoboVac G32 Pro Wheel Replacement: passo 2, immagine 1 di 1
    • Remove four 10 mm screws using a Phillips #1 screwdriver.
  3. eufy Clean RoboVac G32 Pro Wheel Replacement: passo 3, immagine 1 di 1
    • Lift up the wheel.
    • Lift firmly but gently as the wheel's connection to the motherboard is delicate.
  4. eufy Clean RoboVac G32 Pro Wheel Replacement: passo 4, immagine 1 di 1
    • Disconnect the spring from the wheel.
  5. eufy Clean RoboVac G32 Pro Wheel Replacement: passo 5, immagine 1 di 1
    • Remove the motherboard wiring from the wheel.
    • Pinch the white cable connecting the wheel to the wiring and pull.
    • Remove the wheel from the device.
Conclusione
Marist, Team 1-4, Chaterdon Spring 2023 Membro di Marist, Team 1-4, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 344
