Introduzione
If basic troubleshooting does not fix your enTourage Pocket eDGe issues, a full motherboard replacement may be necessary. If you need to replace your motherboard for any reason, follow this guide.
Cosa ti serve
Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
Locate the side of the device containing the motherboard.
Using your J0 Phillips head screwdriver, remove the three 5mm screws from the bottom of the motherboard.
Using your J0 Phillips head screwdriver, remove the four 3mm screws from the top of the motherboard.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Position your device so the inside edge of the motherboard is closest to you.
Locate the three wires connecting the motherboard to the rest of the device.
Using your finger or a pair of tweezers, gently remove each of these from the motherboard.
The motherboard is now connected in only one place on the edge of the device. Being careful of this, flip the motherboard outside of the device, leaving it connected to the foam padding inside of the device.
Carefully pry the small rectangle apart from the thin strip of foam.
If the foam is still intact you may leave the foam in order to reattach the new motherboard.
