Introduzione
Your enTourage Pocket eDGe device may experience problems with the e-reader screen. If you need to replace your e-reader screen for any reason, follow this guide.
Cosa ti serve
Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
Locate the side of the device containing the motherboard.
Using your J0 Phillips head screwdriver, remove the three 5mm screws from the bottom of the motherboard.
Using your J0 Phillips head screwdriver, remove the four 3mm screws from the top of the motherboard.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Position your device so the inside edge of the motherboard is closest to you.
Locate the three wires connecting the motherboard to the rest of the device.
Using your finger or a pair of tweezers, gently remove each of these from the motherboard.
Altre 2 persone hanno completato questa guida.
