Salta al contenuto principale
enTourage Pocket eDGe Battery Replacement
Cosa ti serve
  1. enTourage Pocket eDGe Battery Replacement, Battery: passo 1, immagine 1 di 3 enTourage Pocket eDGe Battery Replacement, Battery: passo 1, immagine 2 di 3 enTourage Pocket eDGe Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the device is powered off before beginning.
    • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
    • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
  2. enTourage Pocket eDGe Battery Replacement: passo 2, immagine 1 di 1
    • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
  3. enTourage Pocket eDGe Battery Replacement: passo 3, immagine 1 di 3 enTourage Pocket eDGe Battery Replacement: passo 3, immagine 2 di 3 enTourage Pocket eDGe Battery Replacement: passo 3, immagine 3 di 3
    • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
  4. enTourage Pocket eDGe Battery Replacement: passo 4, immagine 1 di 1
    • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
  5. enTourage Pocket eDGe Battery Replacement: passo 5, immagine 1 di 1
    • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Great tutorial! I have two of these. Does anyone know where I can buy a replacement battery? I have looked everywhere. I would retrofit if I could find one large and flat enough. 7.2v 2000mA. Hate to have to trash them but they don’t make parts anymore.
Ron - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,449
